recomend me a quiet baffle for a short exhaust
as above i need a quiet baffle for a very noisy short exhaust
i ve seem some with packing an some without an some db killer tubes all on ebay
what are recomedned
someone selling the db killers states they only if you packing in your siliecer an mine is a straight through jesse james pipe could i fit a baffle with packing an then a db killer or this an over kill
just use the db killer
i use them on my xvs and they are effective
are you using the db killer with standard cans or have you removed the baffles
the seller of the db killer says it only works on standard cans that have packing in (an my pipe is hollow with nothing inside)
make a baffle out of perforated tube and bolt it in your can? Or theres the simple circlip and washer trick.
my db killers fitted on straight through pipes
just slips in the end of the pipe and bolts in
The can he has might not of come with db killer. it might be a race can.
