April 17, 201213 yr Hi everyone.I am a good few years old and so are my bikes.My interests are DIY and bikes. I wonder if someone can help me with the problem mentioned in the topic. 1st of all ,the ampage being drawn on ignition is 2.8 amps, 2nd the ampage being drawn with starter pressed is 6.8 amps 3rd voltage drops as low as 6volts to the CDI unit The bike starts if you stab the starter, obviously not letting the voltage drop to such a low voltage level All earths have been replaced and connectors checked cleaned and checked for continuity. I know the bike is 21 years old but as a wise man once said to me "Every problem has a solution" New Lucas battery fitted. Switch on sidestand replaced.Kill switch OK. All earths replaced I would really appreciate any ideas or suggestions within reason! Thanks in anticpation. PS A good day on the Wirral Egg run this year.Good lads and a good turnout alanboyle
April 17, 201213 yr Moderator a compression test? its an old old bike...how many miles? Rings ever changed? Trouble is I dont know what a good reading should be on a 4T? is it in the manual? Greetings alan boyle
