Posted April 17, 201213 yr The last time I was buying fuel for bikes it was four star. When I filled my bike up today I put super unleaded in because I didn't notice. What is the difference, and what are the benefits? But mostly is it wotrth it?
April 17, 201213 yr i think its alot better and makes my bike much more responsive but this could just be because i beleive its better lol, i think its just more expensive and little difference
April 17, 201213 yr Moderator 95 ron is best for bikes as they are designed to run on it. Unless your running high compression pistons, don't waste your money.
April 18, 201212 yr Avoid supermarket fuel, as they dont openly advertise the ethanol content. Which can be lethal in older engines, particularly air cooled two strokes. It really depends on youre riding style and bike. Some fuels have better additives in. For the little I use my DT, I stick with super, its not much to filla 1.5 gallon tank.
April 18, 201212 yr Moderator I'm afraid Ethanol is in most fuels by Govt decree. look for the E5 at the pump. they have E10 in USA which is 10% ethanol
April 18, 201212 yr Author My bike is an XT 125 X and I suppose I ride it pretty aggressively. I was wondering what those fuel additives were, the red one in the little bottle. Are they worth buying? I think I have noticed an improvement in my bike since filling it with super unleaded. I suppose for the extra 10p or so a litre, I might as well buy it, fuel consumption on a 125 four stroke is minimal anyway. Which is the best petrol station? e.g. Shell, Texaco, B.P., etc. I got told Shell were the best.
April 18, 201212 yr Moderator frost sell an ethomix http://www.frost.co.uk/ethomix-additive.html?utm_source=2012_03_14_Ethomix_FBHVC&utm_campaign=Frost+Ethomix+FBHVC&utm_medium=email £12 treats 250 litres. Ethanol is a solvent and fucks up rubber good style. some info here http://www.frost.co.uk/protect-your-vehicle-against-ethanol
April 18, 201212 yr As Drewpy said super 97-100 RON is only really useful in engines running a higher compression than standard, more ignition advance or boost. A higher octane number does not make for better petrol, it makes for a charge more resistant to knock. At present only BMW motorcycles uses knock sensors which can allow the engine to get more power running on super, don't waste your money. It is also a myth supermarket fuel is inferior, the British and EU standards for fuel compel the manufacturers to very narrow variations in formulas. Ethanol, aside from perishing fuel system components (at concentrations above 15/20%), also makes the fuel hygroscopic meaning it will 'go-off' [absorb water] if in the tank for more than a few weeks. In theory above 15/20% the vehicle should be running 'flexfuel' sensors that can alter injection criteria to maintain the stoichiometric ratio (unleaded 14.7:1, ethanol 10:1ish).
April 20, 201212 yr I still maintain that 98 Ron us better for my old dt. It is prone to detonation with premium. It may be luck, but I have only seized my bike/ had over heating problems on supermarket fuel. Ethanol can also potentially lean the mixture too.
