April 17, 201213 yr Moderator I did, it didnt go any slower, but probably no faster either...the thing is I did a few things all at the same time so how each individual change worked out was a bit lost! I must say though I prefer the way I did it to the usual one proffered by others
April 17, 201213 yr Author I did, it didnt go any slower, but probably no faster either...the thing is I did a few things all at the same time so how each individual change worked out was a bit lost! I must say though I prefer the way I did it to the usual one proffered by others what way did you do it?
April 18, 201213 yr Personaly I'm a bit lost. 'Any-one done the above'... and above is the words 'inlet manifold'? Is there a picture missing? What's the question?
April 19, 201213 yr Aye Spurs, reckon you need to ellaborate on that type of mod mate, as mines pretty much been modded to the hilt, and the air intake manifold is a new one on me, unless you mean making it fit a bigger carb, like say a 34mm Mikuni, from a standard 26-28mm one? the only thing I've done to mine concerning that area is to take off the snorkel, so as to lean off mine slightly as it was running a tad rich.
April 19, 201213 yr Author Aye Spurs, reckon you need to ellaborate on that type of mod mate, as mines pretty much been modded to the hilt, and the air intake manifold is a new one on me, unless you mean making it fit a bigger carb, like say a 34mm Mikuni, from a standard 26-28mm one? the only thing I've done to mine concerning that area is to take off the snorkel, so as to lean off mine slightly as it was running a tad rich. click here scroll down on link to find it.
April 19, 201213 yr Ah you mean that modification, well the few people who I know to have done it with their DT's have noticed little, if any difference to their bikes, so I left mine alone, although I did change the reed petals from fibre glass ones to carbon fibre, and noticed there was an added "crispness" to the throttle.
April 19, 201213 yr Moderator Dohh yes that all seemed a bit rough arsed to me so i did mine in a more sypathetic way, like some YZ's were. see post #64 here
April 19, 201213 yr Author Ah you mean that modification, well the few people who I know to have done it with their DT's have noticed little, if any difference to their bikes, so I left mine alone, although I did change the reed petals from fibre glass ones to carbon fibre, and noticed there was an added "crispness" to the throttle. did you have re-jet after fitting the carbon fibre reed petals and do you have a link to them
