Posted April 12, 201213 yr I'm replacing the friction plates in my 1977 DT250MX and there is an adjuster in the centre of the basket. Does anyone know how to set this properly.
April 12, 201213 yr Moderator yes assuming its the same as the 175mX, there is a pointer at the end of the actating arm and a pip on the engine case, gently push the arm towards the front of the engine until it stop's. Adjust the clutch centre screw until the pointer and pip align. After this is done adjust the cable adjuster for 3mm play at the end of the handlebar lever. Now...how about an intro in 'new members'
April 12, 201213 yr Author Thanks for that, can't remember if there's a pip on the engine case but will check tomorrow. Just got the bike a month or so ago and it seems to have been bodged from one end to the other! None of the electrics seem to be working either, that's the next adventure.
April 13, 201213 yr Author Thanks Airhead, had a look and sure enough, under all the grime, there is a wee pip and a pointer! Just awaiting friction plates and I'll getting building it back up.
