Posted April 12, 201213 yr Hello, I have a 1975 Yamaha RS 100, and I have trouble on this simple 6v system for the turn signals, Turnsignals are all mounted and grounded, I bought a new relay switch, When I start the bike and turn the blinker switch to the right or left I hear one click in the relay then I notice that the blinker lights stay on but dont flash, my battery is fully charged, I dont understand why it is not working. If anybody has some info that can help me, please let me know. Thank you, Brendon
April 12, 201213 yr Does the new relay match the wattage of the indicator bulbs ? On the relay it should say something like for example 6V 10w x 2, so you need to make sure the indicator bulbs are all 6V 10w.
April 12, 201213 yr Author relay says 6.4v 17wx2+3w 2 of my bulbs say 6v/17w the other two that came with the bike say t1129 china5k i just assumed they were 6v
April 12, 201213 yr Put the two bulbs marked 6v 17w in the front and back of the right hand side and put the indicator switch to the right and see if that works. You say the battery is fully charged but do the indicators come on without the engine running?
April 12, 201213 yr Moderator I agree with tony here, i suspect the chinese bulbs are 12v, if you have a multimeter a 12v bulb will display a higher resistance than a 6v one...if that were the case there wouldnt be enough current in the circuit to cause the relay to switch on and off
April 12, 201213 yr Author I put both on one side and tried it, it still does the same thing one click and they stay on, these are the original signals too... I did tap the relay with my finger gently and it clicked again, I paid $50 for this relay, is there a way to check if the relay is bad? its a three prong, I also have a Honda st90 if it has a signal relay could I hook it up just to see if its the new relay? Thanks for the reply's, I have done everything to this bike but this simple 6v system is killing me
April 12, 201213 yr Author I put the meter on the battery , it reads 6.2v I have 4 brand new bulbs 6v 17w, new off ebay relay NOS, still they flash once then stay lit, on both sides. I turned the bike on and the vibration of the bike will kick start the relay so they will flash , but if i hold the relay in my hand the just stay on. I turned the signal on and hit my brake And I noticed the signals flashed once and the brake light seamed to flash once also.
April 12, 201213 yr Check to make sure the wiring connectors to the indicators and relay are tight and not corroded and also the bulb sockets are clean. If the brake light flashes as well sounds like you have something wired wrong or a bad earth ( Plain Black wire on Yamaha's).
April 12, 201213 yr Moderator the dash indicator lamp needs to be working as well, its a 6v 3w i think?
April 12, 201213 yr Moderator I took the tach off completely well it needs the extra load of the dash light...small as it is! thats why the relay says "relay says 6.4v 17wx2+3w " Note...+3w
April 12, 201213 yr Author Hmmmm, i really dont want the speedo back on is there , is there a way to bypass?
April 12, 201213 yr Moderator Hmmmm, i really dont want the speedo back on is there , is there a way to bypass? you could try using 6v 21w lamps, see if that works...the flash may be a little faster but you wont know unless you try it EDIT you could even put 21w lamps in the fronts only and leave the 17w lamps in the back, this would give approx the right load for the correct flash rate
April 12, 201213 yr Author Im going to hook the speedo. back up to see if it works. Where would the ground be located at? Thank you so very much for your reply's!!!
April 12, 201213 yr Moderator Im going to hook the speedo. back up to see if it works. Where would the ground be located at? Thank you so very much for your reply's!!! if you just want to see if it works just remove an indicator lamp from the speedo and connect the ends across br/wh and Bk at the relay connector...it will be quicker for you
April 12, 201213 yr Author I connected the speedo, it still did not work, but when I started the bike the left side worked, slow but worked. the right side just stayed on
April 12, 201213 yr Moderator Being as this has become much more than just hello, i'm moving it out of new members
April 12, 201213 yr Moderator ok so thats a step in the right direction then now try this, use a piece of wire as a jumper, touch one end to battery+ and the other end to Brown on the relay connector, see if the indicators work...dont think you will need to turn the key ON
