davidm90 Posted April 11, 2012 Posted April 11, 2012 Hi there, New to this forum and looking for help if possible. i have recently purchased a DT 125R LC well so im lead to believe. i will post pics soon. any way my problem is that the bike wont kick start. does not have key or electric start as its a field MX bike. i have checked and im getting a good spark. i have compression. im getting fuel from the tank to the carb and ive also stripped and cleaned the carb. but the bike wont start even with a bump start. i tried pouring a little fuel down theplug hole directly into the cylinder. when i done this the bike fired up then cut out. so my thoughts are that the engine is drawing air and not inducing fuel through the crankcase into the cylinder. am i correct? i have ordered new gaskets for the engine spark plug piston and rings. ive stripped the head and bore off the engine to carry out partial rebuild. is there much more to do for a complete rebuild after the bore is off? could anyone give me any pointers to why my bike doesnt start or to rebuilding my engine? thanks david
davidm90 Posted April 12, 2012 Author Posted April 12, 2012 Does nobody reply on this forum? :/ really needing some help. Thought I'd get some here
Moderator Airhead Posted April 12, 2012 Moderator Posted April 12, 2012 some knowlegable members like to see an intro in new members before the questions david...its a forum etiquette thing ya know
davidm90 Posted April 12, 2012 Author Posted April 12, 2012 Sorry air head. New to the whole forum thing and really didn't think anyone would take notice of an intro. I've done so now.
Moderator Airhead Posted April 12, 2012 Moderator Posted April 12, 2012 always a tricky one this i find david, its late now but tomorrows another day mate
davidm90 Posted April 12, 2012 Author Posted April 12, 2012 Ok buddy I'll be out working on the bike tomorrow night so give you a few questions tomorrow if that's cool?
Moderator Airhead Posted April 12, 2012 Moderator Posted April 12, 2012 throw up a pic of the bike, the ability to post pictures is always a bonus...see FAQ's in 'New member' forum
davidm90 Posted April 12, 2012 Author Posted April 12, 2012 Read the faqs think I know how to post a pic. Here go's
davidm90 Posted April 12, 2012 Author Posted April 12, 2012 Theres the old girl there when I bought it. Is it the correct bike I've been informed I've bought? DT 125 R LC??
blackhat250 Posted April 13, 2012 Posted April 13, 2012 Welcome davey " she looks like its had a hard life, well on your info , am thinking compression [ lack of ] if thers fuel, spark, , when you cleaned carb, did you remove jets, ? also is the choke working,? ,,,
davidm90 Posted April 13, 2012 Author Posted April 13, 2012 Cheers for the reply black hat. I have Took the bore and head off and there seems to be no damage. But I've bought a piston and rings to replace them to be sure. Yeah completely cleaned the carb. I'm not sure if the choke is working. I tried kicking with the choke up and no difference. How do I check if the choke is working?
Moderator Airhead Posted April 13, 2012 Moderator Posted April 13, 2012 the choke..well does the plug get wet with fuel?
davidm90 Posted April 13, 2012 Author Posted April 13, 2012 i had put fuel down the plug hole and kicked it and it started up but then cut out. and then i gave it a few more kicks and then checked the plug and it was wet with fuel yeah. does that mean the choke is knackered?
Moderator Airhead Posted April 13, 2012 Moderator Posted April 13, 2012 nah but it could have been wet with fuel you put through the plug hole. what i meant was...without putting fuel in manually, does the plug get wet with fuel by the way you should buy several spark plugs and try them all, sometimes they can be a bit finicky
davidm90 Posted April 13, 2012 Author Posted April 13, 2012 I've got a new one there but at the moment ye bike is stripped and completely in bits. Gonna give it a rub down and paint the frame and stuff. Hopefully give it a new lease of life. But as I said I've got the bore and head off it to change the piston and rings and renew all the gaskets. Them that way I know it's right because I think the last owner tried it as there was a load of sealer and stuff around the gaskets.
davidm90 Posted April 13, 2012 Author Posted April 13, 2012 But once I've done that I'll check it's not flooding. How would I fix it if it's flooding?
Moderator Airhead Posted April 13, 2012 Moderator Posted April 13, 2012 see how it is after the rebuild dave and try a few plug, dont know why you mention flooding
2 Wheels Posted April 14, 2012 Posted April 14, 2012 Welcome David. You should have tried harder to get her starting before you pulled the head off. You could now put it all back togeather and find that it has perished crank seals,,,,,, then you will be stripping it all again. Let us know what the story is eh!
davidm90 Posted April 15, 2012 Author Posted April 15, 2012 How much more work is involved with a whole rebuild? Instead of just a top end rebuild?
