Best value chain lube
SubzeroYBR
This post is 4545 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
wurth stuff is good, I use motorex 622.
spray the chain after a ride while its still warm and let it set overnight, wipe excess off and it shouldn't spray oil everywhere.
Depends what sort of mileage you are doing, I try to do mine once a week at the moment but im travelling less than 50 miles in that time. -_-
You should be cleaning and lubing the chain more if you use it a lot in the rain, just keep an eye on it and make sure it doesnt dry up.
Not all of us like riding in the rain if we dont have to :blush:
Just brought some Wurst and it seems pretty dam good. No back spray at all! Would recommend it and yep been 'advised' to lube the chain after every 'wet' ride and/or after cleaning the bike.
As Drewpy mentioned, after a ride is better as the chain is warm and 'open' to allow the lube to penetrate more.
