April 11, 201213 yr Hi guys I have bought a new YBR125, and the guy said I should lube the chain every other day. What is the best value lube, not too expensive but good quality? Cheers
April 11, 201213 yr Moderator wurth stuff is good, I use motorex 622. spray the chain after a ride while its still warm and let it set overnight, wipe excess off and it shouldn't spray oil everywhere.
April 14, 201213 yr Hey guys, I'm new to this too. Do you really have to spray every other day? Cheers
April 14, 201213 yr Depends what sort of mileage you are doing, I try to do mine once a week at the moment but im travelling less than 50 miles in that time. You should be cleaning and lubing the chain more if you use it a lot in the rain, just keep an eye on it and make sure it doesnt dry up.
April 16, 201213 yr Just brought some Wurst and it seems pretty dam good. No back spray at all! Would recommend it and yep been 'advised' to lube the chain after every 'wet' ride and/or after cleaning the bike. As Drewpy mentioned, after a ride is better as the chain is warm and 'open' to allow the lube to penetrate more.
