April 11, 201214 yr Hey all, I am in the process of getting my 1970 R5 on the road after a few mechanical improvements but am looking for a little help with the electrical, hoping you guys might have some thoughts on this. I've purchased some turn signals for her, but am not sure of their installation. In the rear, bundled up in the stoplight bracket, are a few wires, and I think only a three of them should be there, the others look like they might go to the turn signals. To the stop light, there is a yellow, blue and black, that all go to the stop light socket. Those three look like they belong there. There is also a brown, and two black there, with wire nuts on them (nice). I think one of the blacks should be a green wire that was just replaced with a black. I think the brown is the Left turn, and the other black is a ground. Under the seat, there is a brown and a green coming from the front of the bike, just clipped off. I would think these are the wires that should be connected to the back turn signals. In the headlight bucket, nothing seems to be unplugged, so I'm not sure what to connect to there. Doesn't look like anyone's messed with that harness. I sure would appreciate some help, wiring is not my thing. Thanks.
April 11, 201214 yr You are right in that there should be two wires going to each indicator. Dark green is the feed to the RH side indicators with a plain black being the common earth on Yamaha's and Dark Brown is the feed to the LH side indicators with again a plain black for the earth You should have a Dark Brown and a Dark Green in the headlamp shell unless someome has cut these as well. hope this helps. Tony Edited April 27, 201214 yr by alexasigno Removed link to copyrighted material
April 13, 201214 yr Author Tony, that really does help. Thanks! I do have a follow up question if you don't mind. Since the front and rear indicators only have a single wire exiting, am I to assume that bolting them to the grab rail and headlamp shell will provide the ground? I appreciate the help and the diagram. Mike
April 13, 201214 yr Just had a look on the parts list here http://www.yamaha-mo...L_R5_(R5_-_1970) and it shows a seperate wire thats held on to the indicator stud that provides the earth which should plug into a plain black in the harness. Tony Just clicked on link and it doesn't go straight to it but if you select : Step 1 Motorcycle Step 2 1970 Step 3 R5 Step 4 Turnsignal you will see item 9 which is the seperate earth wire Tony
April 15, 201214 yr Author Thanks guys. Seems like an odd way to ground the wire, certainly more chance of coming loose. But hey, we'll see what happens. Hope to let you know when they're functioning. Not sure why I want to get the directional lights working, it seems like most drivers consider them "optional equipment". Just trying to stay safe... Appreciate the help, Mike
