hi
Have a weak spark on all 4 could it be the regulator/rectifier.
it was running fine then started to miss fire and stalled i bumped it and it ran for a few minuets then did the same again and now it wont fire up.
Fitted a new battery but still the same.
Cheers
Sorted
the coil connections were loose so that sorted the spark then it was not getting fuel to the carbs.
The plank i brought it from had fitted a fuel filter and used jubilee clips.
he had them that tight he crushed the fuel line.
All sorted now and back on the road
