April 10, 201214 yr yeterday i replaced the cylinder and cylinder head gaskets following the workshop manual all went well and every thing went back together fine. started her up and she ran on half choke fine until warm then sat on tick over for about 4-5mins with no problems at all so i turned her off and put the side panels back on. tried starting her again but she would only start on full choke and then splutter to a stop checked all ground cables are secure, got plenty of fuel, got a spark, airbox and tubes are clean and clear. tried to start her again this morning and she wont start at all not even on full choke. any help or suggestions would be appreciated.
April 15, 201214 yr Author Spark plug is brand new. I've now sorted the problem I had split the intake manifold when putting the carb back on, so it was just sucking air in and no petrol, I've super duper glued the split and she now runs like a dream, new manifold should arrive early next week fingers crossed I don't split this one
