April 6, 201213 yr HELPPPPPPPPP As some of you know i have a faulty pick up coil, i can get a universal one with 120 ohm resistance and one with 280 ohm resistance, now the question is the one i have is supposed to have a resistance of 182 ohm - 222 ohm ( haynes figures ) so which one is suitable
April 6, 201213 yr Moderator dunno, it is outside the recommended tolerances so shouldnt really be used! have you tried electrex world or west country rewinds,,,or ebay...or yamaha (fowlers)?..really you should use whats right
April 7, 201213 yr Author dunno, it is outside the recommended tolerances so shouldnt really be used! have you tried electrex world or west country rewinds,,,or ebay...or yamaha (fowlers)?..really you should use whats right that is from electrex £30, fowlers £130 and wouldnt budge !!!
April 7, 201213 yr Moderator that is from electrex £30, fowlers £130 and wouldnt budge !!! I would ring electrex after the holidays and see what they say about the out of tolerance issue
April 7, 201213 yr Author I would ring electrex after the holidays and see what they say about the out of tolerance issue you read my mind, will post up their answer should anyone else have any probs
April 7, 201213 yr Moderator if they cant help for some reason have a word with west country windings with a view to having your old one re-wound to in-spec
April 7, 201213 yr Author if they cant help for some reason have a word with west country windings with a view to having your old one re-wound to in-spec cheers buddy,
