Yeah drewp look in the manual you dumb shit! :crazy:
  • Replies 286
  • Views 42.5k
what does the manual say then?
I'm using the AM6 12v system.
I do have the Derbi Senda one which doesn't give that information as they assume that the mag will fit on via the woodruff key (which it will for a derbi senda)
what does the manual say for the original system FFS
line up the line on the mag to to the mark on the casing.
means nothing in this case as there is a new crank which has a different keyed cutout for some reason.
  • 4 weeks later...
right, the new crank has an old style taper so the AM6 system is out now Boooo! :shakeno:
So I asked mr Bob and he recons its the CEV mag I need as there are 2 part numbers for ols crank and new.
Guess what, I had a CEV mag originally so after a bit of juggling around it fits. The only issue I have is the key way is different.
Just used the Dial Gauge ( thanks Airhead) and found tdc and had to spin the coils 180' ish and luckily the backplate holes line up with the threads. Just need to buy new contacts as these ones are worn and I will replace the condensor too as I'll rewire the Mag.
Managed to get a spark, so onwards and upwards :)
Made a new wiring Loom for the Gilera today.
Just need to get the flywheel done, although I am getting a better spark now!
Woo-hoo! Bet that feels good! :yeah:
  • 1 month later...
Bob Wright has just emailed me to say the final parts are on their way, yippee
have the frame and fork legs at the local TIG welder to make a better job than me.
Get the frame to the powder coaters next week and then should be on the final build
Great news Drew :hyper:
just found this on the Swedish site
its a heater for the colder months, keep the cockles warm :)
EERRRRR UMMM exactly where does the pipe go to and how does it attach? ..... what kind of sex porn you selling here...................... you stick it WHERE ! I don't think so...... talk to foams
Bloody hell. That looks OLDSKWL!
Interesting project. I take it parts for these are solid to find?
its the down pipe, and I assume the funnel catches the moving air, warms up around the down pipe and comes out of that end. To where it goes from there, who knows?
A bit hard now and they are commanding ££'s, theres a rough one one ebay for £995 ATM and needs the lot doing.
Just done a calculation and spent £1562.12 so far, including purchase price. That doesn't sound too bad :)
That's good. My project has cost me more and parts are more widely available.
should be ready for squire's Drew!! I was 200cc down to you last time this should even things up hahaha
I'll need to fit pedals to keep up :babyha:
