May 3, 201214 yr Moderator how are you going to torque up the flywheel nut to the specified torque this time?
May 3, 201214 yr Author Not yet ive got it on tight but goin to borrow my mates torqe wrench tomorrow.
May 3, 201214 yr Moderator yes but do you know the torque setting, and how are you going to stop the flywheel turning while you tighten it??
May 4, 201214 yr Author Ive still got the head off so will put a bar through the conrod. Downloaded a manual lastnight so got the settings. Cheers pal.
May 4, 201214 yr Author My matd had my old piston so got a ring off that thank god. Put engine back in and it started straight away and runs a dream : )
May 5, 201214 yr Wow, what an intense thread. I hope I never have the misfortune of buying this bike!
May 5, 201214 yr You put an old piston ring in? Personally i would have bought new rings and waited a couple of days.
May 12, 201214 yr Author Yes it is lol, its all part of learning though. Its still running well and worn in done 350 mile now so i can use my ypvs again : )
