Posted March 27, 201213 yr Hi people, has anybody fitted a tail tidy to their bike, i have but now number plate touches the back wheel. Would like to know if anybody else has had same problem
May 31, 201213 yr Did you sort out this problem ? What make tail tidy did you buy ? Just wondering as I am thinking about getting one myself .
June 2, 201213 yr The easy way around the problem is to drill new holes in the plate to lift it higher up and so away from the wheel
June 21, 201213 yr How big is your number plate ? lol. You may just need to put some new holes in it to bring it up the bracket a bit more. Or go and get a slightly smaller one made up.
June 25, 201213 yr with mine i bent the bracket out because when my gf got on the back after drilling holes higher it touched wheel still
July 2, 201212 yr I had an XJ6S (half faired version but mechanically the same bike) for over a year. The XJ6 will handle realistically everything you throw at it, is not supersport but has a fair amount of get go, comfortable for the pillion, comfortable to ride, the underbody exhaust is fairly quiet but the plus is no damage if you drop it or fear from the pillion from burning. Quite a solid bike, suspension can be a little bland when pushing it hard-ish (not a racer here) but for the budget I think you get a lot of bike for the money. Direct competitors the Kawi ER6, different engine, similar power, more vibes than the XJ6. For commuting I think is an excellent bike, fairly narrow, easily flickable through traffic.
August 4, 201212 yr I fitted the Evotech 14,000 miles ago and no problems here, maybe a picture might help. Cheers
August 22, 201212 yr I'll be picking mine up at the end of September (hopefully one I pass my test that is). Anyway, I'll need to put a screen on of some fashion and perhaps a few other bits. Can anyone recommend anything? Thanks
September 25, 201212 yr I purchased my XJ6n march 2011, and have done a few alterations.Had Belly Pan Sprayed same as Tank,Tail Tidy Fitted,Wheel Hugger,White Reflective Wheel Tapes,Leo Vince Slip on Exhaust,K and N Air filter, Its a real nice bike and now sounds bloody great,The Air Filter helps improve acceleration,sorry I havent got any other pictures on here other than profile picture.
January 26, 201312 yr I know this was way back in september , can't believe I have not been on forum since then. In the end I fitted the Evotech tail tidy . Highly recommended , bit of dismantling of bike required to remove original parts but that will be required whatever tail tidy you buy . I work in the motor trade but I consider it a easy DIY job to fit the Evotech tail tidy. It was a reasonable price and good quality parts , looks good fitted .
