Hi all,
Does anyone know where I can down load a manual for a xt125r as it is not listed on Yamaha website, my digital speedo display won't work and I've checked the main fuse. Does any one know if the display module has a back up battery ? Everything else works fine and the problem is only since the battery packed as the bike was in hibernation.
Thanks all
Dogmi
You can buy one from Halfords, it has the YBR, XT125X and R models in it.
Had problems with my speedo recalibrating it a while ago, try disconnecting the battery for 10 minutes and then reconnect it, set it to enduro by turning the key when the display says enduro. No back up battery for the display though.
Matt
Thanks Matt, ive ordered one from halfords but I'm dreading the fact I think the display is a gonner, checked all the connections and I can't figure it out.
Dogmi
  • 2 months later...
My display died today too... they're rubbish :(
