Tacho going crazy
Hi guys,
My first time using this forum.
I have an XJ900F and when I turn the ignition on (without the motor running), The tacho immediately swings around to full revs and then hovers around the 8,000rpm mark. There is also a buzzing sound coming from under the tank. The motor won't start, but was running fine previously.
Welcome rodjen " sounds like a relay,, you"l need a manual ,,,and a meter, :movingeyes: :movingeyes: :movingeyes::smash:
Hi
Some Yamaha models use the rev counter to show error codes, My old Divi 900 used to use the rev counter to indicate some error codes, pehaps your 900 could be similar.
