gear change problems
hi can any 1 help. I have 96 xj600n but having problems changing down the gears usually from about 3rd downwards. It changes up fine just comming down is problem. Within last year had new clutch plates fitted new clutch cable and chain and sprockets. Was fine for a few weeks after work was done but now problem has started. Any advice would be most appreciated
Hi Will, and welcome to the forum.
Where are you from?
It is advisable to introduce yourself in the "New Members" section first, Believe me, you will get more help that way.
But, as I'm in a good mood I will try and help you.
My personal feeling is that your problem is, that it is the clutch needle bearing.
thanks mike 1949 will have a look at that and will introduce myself . Many thanks again
