DT175 battery Drain problem
This post is 4633 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
HI! :)
I have got a little problem with my DT175, the battery seems to discharge itselfe, so i have to charge it about once og twice a week :(
I have tried meassuring the voltage coming out of the + and - from the wirering harness, without the battery on, and it says 14,6-15V, which is (according to the maunal) okay.
Anyone who knows what the problem might be ?
The battery is quite new, got it just before winter, but it saddly got left out a few weeks in the frost.
Thanks!
What rpm, any acid/water in the battery.
16v at 3000rpm! Whats it making at 6000?
Where exactly are you in the world. I would check your info on that voltage, its generally checked at 5-6000rpm and 16v is high TBH.
