xt500 brake shaft
the rear brake pedal on my xt500 is a bit sloppy so changed it for a new part but it has not made any differance to the play. is it correct that it is only pushed through the frame and the brake pedal clamp is the only thing holding it in place?
Hi 18j
There is a very shallow nylon shim inside the tube housing on the frame, unfortunatly there is no part number for this
but if you can find some small bore plastic tubing you may be able to ream some out.
TTB
must be bloody thin then, no wonder i couldnt even see it on a parts diagram, any ideas on what tubing can be used?
I would say its only about 1mm thick but i have never had to replace one yet so i cant offer any advice of the tube you need.
Maybe some thin brass strip will be better.
TTB
thanks tommy, i will make some enquiries about getting one machined from nylon, having never seen the item in question is there a pic anywhere? is there a shoulder on it on the inside to sit against the frame on the inside where the return spring sits. i have the dust covers on order so may have a better idea when i see them.
thanks wayne
could work, i'll have to remove the shaft and take some measurements.
thanks wayne
Here you go ,these picture where taken when i restored my 500E a few years ago so hopefully they will help.
PM sent as well.
Cheers TTB
