March 6, 201214 yr I've got a 73 at3 125 that runs great but won't go into gear. I've pulled both side covers off. I can get the clutch push rod out on the right side (I'm almost positive it's a two piece rod with a ball) but the other rod seems to be stuck. If I turn the the adjustment screw it appears to push the rod some. Am I missing something? Is there anything else that could be holding the rod in place? any help would be great!
March 6, 201214 yr Author It's been sitting at least 15 years! I pulled the plates off and separated them. I finally got both push rods out and the ball. Put it all back together and still getting the same thing. It seems to go thru the gears fine. I would think if the transmission was locked up I wouldn't be able to get it back in neutral. I don't know what to try next
March 6, 201214 yr Moderator is there a pointer on the clutch operating arm and a mark on the top of the case?
March 7, 201214 yr Moderator do this, slacken the cable adjuster. Then adjust the clutch adjuster until the pushrod meets the pressure plate and resistance is felt back off the adjuster 1/8 turn and do up locknut Adjust cable adjuster for 3mm free play at the lever end All this is just a guess but may help
March 9, 201214 yr Author figured it out once I took the the whole basket off. The bearings were stuck.
March 15, 201214 yr Author I'm now able to shift gears! Now the only problem I have is that I can't get it to shift back into neutral while it's running. Once I turn off the bike it shifts in to neutral just fine. Any ideas?
March 15, 201214 yr Moderator Clutch drag? Now its running have you adjusted the clutch again, as now it has actually run all the parts will have settled after the initial set up.
