1973 125 At3 clutch problem
I've got a 73 at3 125 that runs great but won't go into gear. I've pulled both side covers off. I can get the clutch push rod out on the right side (I'm almost positive it's a two piece rod with a ball) but the other rod seems to be stuck. If I turn the the adjustment screw it appears to push the rod some. Am I missing something? Is there anything else that could be holding the rod in place? any help would be great!
How long was the dt standing ? the plates could be stuck together , :eusa_think:
It's been sitting at least 15 years! I pulled the plates off and separated them. I finally got both push rods out and the ball. Put it all back together and still getting the same thing.
It seems to go thru the gears fine. I would think if the transmission was locked up I wouldn't be able to get it back in neutral. I don't know what to try next
I'm not sure. I'll check in the morning. If so what do I need to do?
do this,
slacken the cable adjuster.
Then adjust the clutch adjuster until the pushrod meets the pressure plate and resistance is felt
back off the adjuster 1/8 turn and do up locknut
Adjust cable adjuster for 3mm free play at the lever end
All this is just a guess but may help
figured it out once I took the the whole basket off. The bearings were stuck.
I'm now able to shift gears! Now the only problem I have is that I can't get it to shift back into neutral while it's running. Once I turn off the bike it shifts in to neutral just fine. Any ideas?
Clutch drag?
Now its running have you adjusted the clutch again, as now it has actually run all the parts will have settled after the initial set up.
