dt 125 r 1988 wiring problem
hi i hope some can help i have a dt 125 r 1988 the headlight works when the bike is running but no rear light i have checked the blub thats ok . also i have no brake lights and no horn or neutral light with the ignition switched on has anyone got any ideas please thanks mat
batterys is all good its brand new and there is no fuse it looks like someone has taken the fuse out and by passed it . the fuse should be in were the battery is if i am right
hi all just checked the wiring there is no fuse in the wiring loom i am stil lost why i have no lights only the headlight when the engine runs and no rear light brake light or horn
thanks mat
Hi Mat
Have a butchers at Nev's thread in the projects as he's got an absolutely idiot proof wiring diagram. I know it's idiot proof, it worked for me ;)
Welcome matt" did all these lights work before ? or are you tracing non working electical faults, ie, someone"s butchered the loom ,
hi all thank you for pointing me in the right place you are right it is an idiot proof loom. all the lights did work before this happened on looking further at the loom someone has butchered the loom . thank you all for your help .
thanks mat
