Posted February 26, 201213 yr Hi, I am confused as to the air pressure in the front forks, my local Yamaha dealer sys the pressure should be 0lbs yet my clymer manual says between 5 and 0. Is this with the irks under or off pressure? Thanks Steve
February 27, 201213 yr On my powervalve 350, 5psi is the standard air pressure, 0psi is the minimum and 17psi the maximum. When checking make sure there is No weight on the forks i.e: with the front wheel off the ground. Tony
