Posted March 9, 200520 yr im very new to this forum so i apologise in advance for not nowing how it works and my spelling. the rear brake caliper on my dt125lc is knackered and i cant find 1, will a front caliper fit? would i have to make a plate to hold the it in place? cheers
March 10, 200520 yr im very new to this forum so i apologise in advance for not nowing how it works and my spelling. the rear brake caliper on my dt125lc is knackered and i cant find 1, will a front caliper fit? would i have to make a plate to hold the it in place? cheers are you sure its a DT125Lc? The dt125lc's have a rear drum brake. The dt125R has a rear caliper. What year is your bike??
April 4, 200520 yr Author are you sure its a DT125Lc? The dt125lc's have a rear drum brake. The dt125R has a rear caliper. What year is your bike??
April 4, 200520 yr Author im not sure of the year of my bike, i bought it as a scrapper in order to chop off the front end for a trike but after cleaning and a few mods i got it running. i had a dt125lc when i was a teenager, apart from the brakes it looks the same. i have took of the front brake to put on the back but the braket spacer that holds it is snapped(the reason it has no rear brake) ive made a new braket and put a rear brake on so iv no front brake now. im having probs with the carb now tho, ive stripped and cleaned it but no fuel is coming throu it. all the jets are clear but nothing, using a drip into the rubber carb mount, the bike runs but the carb doesnt. any advice.
