Posted March 7, 200520 yr I bought last autumn old RD 125 LC 1984, 21.1 hp/15.5 kW. It was been two years under tarpaulin. I replaced oil and cooling liqued and bought new accu. The motor is OK.The fuel tank and frame is black and rear sub-frame is like silver. Can anybody say certainly original paint codes or what kind of paint I can use if I will restrore my bike? Regards Seppo
April 16, 200520 yr I've been searching for paint codes,etc. for the yamaha enduros to 71. no luck so far. I'm begining to think this info. is non-existant. I have used a trick on other bikes that might work for you. If there is any paint left on the tank it will be in the best shape on the under side. I've used Dupont color chip book to match the color. This will work if it's solid color or metalic color. If it's a candy color (two stage) this won't work. I have a shop that repaints vintage bikes and I always have problems with colors.
April 28, 200520 yr hellow... Iam refuring to your add.. I have got Yamaha 125.. and it has the original paint on... I dont know the paint code.. but I can tell you, the coller is dark red.. like a dark vine red.. Hope this helps you... )
August 19, 200519 yr Someone here may be able to help http://rd125lc.proboards25.com/ http://www.rd125lc.co.uk/
