February 3, 201214 yr hi guys, new to this forum and this is my first post and i really hope you can help with my problem. i've just purchased a 2000 dtr125 as a project, it had been converted to off road use by the previous owner who obviously didnt have a clue what he was doing! and now it has no spark and wont fire, the ignition and kill switch are both missing at the moment, so any help with what the problem could be will be much appreciated :spin2: thanks
February 3, 201214 yr Moderator Have you got a haynes manual, are you going to get one? There will be wiring diag's in there First post so feel free to do a quick intro in new members forum
February 4, 201213 yr Author i havent got a haynes here, but i have found a wiring diagram on the internet thank you very much!
February 10, 201213 yr Author if i wanted the kill switch and ignition to work, would i just connect the wires together? or..?
May 13, 201213 yr Hi, im new tyo this forum also, but i do know that there is an ignition spark relay switch under the seat at the rear left of the frame, it is held in place by a black square rubber hanger. There are 4 wires connected by a block connector that fit into it, it is one of the daftest places to hang a relay switch as it is open to all the dirt and water that the back wheel kicks up. Ive repaired a few DTRs with this problem and i always relocate the relay switch to the top of the air box under the seat, this keeps it nice and dry and out of the road dirt. Its only £10/£12. Check to see that the relay is still present, chances are that it may need to be replaced.
