curt656 Posted January 29, 2012 Posted January 29, 2012 hi i'm new on here just got a dtx 125 first ride out last weekend damm thing siezed up (think oil pump died) got the chance of a 2002 engine mine is a 2005 my question is will it fit & what will i have to change regards
Moderator Airhead Posted January 29, 2012 Moderator Posted January 29, 2012 Greetings curt well it might fit but wont be leccy start! If it were me I would want to keep with the original engine for the registered engine number, and having said that would be looking to repair the damage
curt656 Posted January 29, 2012 Author Posted January 29, 2012 hi airhead thanks for reply i will be doing my own engine up but it needs a lot crank, rebore & new piston so in the mean time i have been given the chance of a 2002 engine cheap for now i knew about kick start just not sure if generator electrics are the same any help off any body is welcomed
Moderator Airhead Posted January 29, 2012 Moderator Posted January 29, 2012 I wondered about the stators too, unless the 05 stator will fit the 02 engine, i doubt you will find the answer to that without buying it, also compare the numbers on the rotors before mixing them up and note it down
