January 27, 201214 yr Please help me if you can XJ600N Diversion 1999.and it is limitet in kilowtts (23kw) Question is ......where it will be removed and they are blocking ??? Thank you all!
January 28, 201214 yr I've got a Yamaha technical information book that lists two Genuine 25 KW restrictor kits for the XJ600 S/N. The one listed for the 1992-1995 XJ600N/S is part number # KIT-XJ60S-25-KW and mentions 4 x Inlet port plates that go between the inlet point joint rubbers and the cylinder head and 1 x throttle stop screw and 1 x throttle stop screw spacer that goes between numbers 2 and 3 carbs. The one listed for the XJ600N/S 1996 and onwards is listed as part number # KITXJ6SN-25-96 and mentions 4 x carburettor slide restrictors that go on the top and bottom of the carb diaphragm springs. Tony
January 28, 201214 yr Hiya Kapone Might be a good idea to introduce yourself as a first post, I am sure you would get all the answers you need (There are a lot of clever people on this forum willing to help) Tony...
February 11, 201214 yr Mate, hi... my divvy's restricted *coughs* too and they're fitted *ahem* at the inlet ports as mentioned above... though its a 98... easy job to check; tank off, air box off and without taking the rubbers off you should be able to see them, if that's what your kit is...
