January 23, 201214 yr Hi all, i wondered if anyone can help with this, i am trying to set the float heights on my 1984 xj 600 my haynes manual says 16.5 to 18.5 mm but when you try that measurement the float is almost touching the carb, so i set thm at 22mm as a guess which resulted in flooding of two carbs.I am trying to set them because the carbs have been messed with by various others and were all over the place,the bike was running great up to 5000 rpm then struggleing after that as if fuel starvation.
