January 21, 201214 yr hi. having problems with a intermittent weak spark.set plug lead 6 mm. from cyl. head, great spark, suspect ngk resistor plug cap. put plug only finger tight in head, kicked her over, no spark. can anyone help me, thanks bj.
January 21, 201214 yr Elimination process" change cheapest component first,, , do you have a meter " [ohms] and a manual ?
January 21, 201214 yr Moderator replace the plug and plug cap and try again, not really expensive to do
January 22, 201214 yr Author good morning,thanks blackchat &airhead for replying.got my haynes & multimeter.new points, new ig.coil. new wire from mag.resistance of mag coil ok. removed plug & ngk resistor plug cap . set ig. plug cable 6mm from cylinder, 4 out of 6 sparks only. thanks again. bj.
January 22, 201214 yr Moderator 4 out of 6 eh, try disconnecting the capacitor during the checks? 10/10 ? new capacitor required !
January 23, 201214 yr Author thanks airhead, new capacitor& plug fitted, no joy took cap. out of the circuit, same result, thanks for all your help, b j.
January 29, 201213 yr Moderator "thanks airhead, yes i have an haynes. today put ht lead 6mm from head bolt, great spark. screwed in plug, not connected to ht. lead, not a spark in site????????? any clues greatly appreciated bj." say that again?...but differently did you mean screwed in plug cap, fitted plug and rested on cylinder = no spark?
January 31, 201213 yr Author thanks airhead, no plug not connected to ignition coil lead, plug screwed into cyl. head, no spark what so ever thanks bj.
