January 15, 201214 yr Hello I'm new here, I have just brought myself a 2006 white and red yamaha R6. It came with a Ohlins steering damper, But it seems to rub on the top yoke nut? Here's a few pics Cheers
January 17, 201214 yr Is there any chance of getting a spacer or washer of some sort in there to lift it up a bit and off the nut?
January 17, 201214 yr Found this, perhaps you can check too see if you have everything installed correctly. https://www.motomummy.com/SD183.pdf Tony
