DT 125 RE - Barrel leak, Head leak? - 170cc athena
This post is 4691 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hello all, as some may know i recently bought a dtr and i had my very first ride on it yesterday and after a long hard ride i noticed that barrelt had nasty runs down from the head and it looks like the head gasket is knackered, i will provide pictures soon, i was just wondering if anyone knows where to get the athena 170cc gasket for my dtr as the only one i can find is this http://www.ebay.co.uk/itm/YAMAHA-TDR-125-TOP-GASKET-SET-ATHENA-KIT-65MM-170cc-/280551840052?pt=UK_Motorcycle_Parts&hash=item4152315934
Thanks for all the help!
Thanks airhead, although i still couldnt find the gasket :biglaugha: heres a picture, it's taken from my mobile so its not a great picture 378977_2753963962916_1072189654_2817762_1594727724_n.jpg it seems to be leaking from the front of the barrel AND the head.. i was told when i bought it that its the 170cc barrel - trying to find a gasket for it is horrible!
If it was warped would it run bad or is there any other way of checking it because I don't really want to be pulling it apar, but I'll ask my dad to have alook as he is good with these things, thanks again
well you will have the head off to change the gasket, all i'm saying is while its off check it, the chances are it will be fine but if it is warped you may soon get another leak
Ok, i'll get the gasket ordered and get him to check the barrel for me, i'm starting to think this is why i got the bike so cheap and a spare barrel - hmmmmmm
UPDATE: I ordered the whole top end gasket kit although now i have noticed that it isnt using much water at all.. and the leak looks to have stopped, o i have cleaned the marks off that was on the head and barrel and i'm going to keep an eye on it - Thanks for your time Airhead, Much appriciated!
i'll have a go at it, by torqeing what do you mean? i think i know what you mean but just to be certain could you please explain :eusa_think:
Ahh just make sure none of them are too loose but dont 'murder' them either, it takes experience and i feel you havent got much of that?
hopefully they will feel tight enough.
When tightening the head bolts do it in opposites otherwise you will be there all day and none will tighten up.
You probably have a spare barrel and is most likely the original as when you buy the Athena kit you get a whole top end including barrel with it.
