kayos Posted January 14, 2012 Share Posted January 14, 2012 I have been having a go at getting an old V50P going (see projects) - well it was going when I took it apart!! What have I done: I have replaced the piston, changed the original fuel tap for a on off type - this has a slightly smaller outlet than the original. replaced the points and set the timing. put on new exhaust. The problem is that it works fine in first gear but has no power at all above 10mph or up hills - basically wont go in 2nd or third. The clutch is OK. Any ideas as to the problem. Ta KAYOS. Link to comment Share on other sites More sharing options...
Moderator Airhead Posted January 14, 2012 Moderator Share Posted January 14, 2012 1: you put the piston in back to front ? 2: where is the condensor i cant see it? Link to comment Share on other sites More sharing options...
kayos Posted January 14, 2012 Author Share Posted January 14, 2012 Ah no the piston is in OK - the condensor - that should be by the points, I have not touched that - I will have a look. Link to comment Share on other sites More sharing options...
kayos Posted January 15, 2012 Author Share Posted January 15, 2012 The condensor is situated below the points - looks OK Link to comment Share on other sites More sharing options...
