dt 125 help
hi a need help i have just rebuilt my dt 125 and when a turn the key on there is no spark from the spark plug but when i turn the key off there is a spark it has got me puzzled so if any1 can help
Thank you michael
sounds like bad earth somewhere , or most probably the main (key) switch knackered , have you checked the side stand switch ?
thank you for all you help a found out it was to do with the electic start live because i had to change it to kick start because of the new engine al sorted now thanks again :spin2:
