fazer fzs brakes need bleed
hi all help would be appreciated i fitted hel lines to my 01 fazer today and having bother getting a brake on front wheel lever is soft and spent a long time pumpin lever to no avail back brake fitted and bleed in 10 mins
Hi ive had same problem in the past and found there are two ways to bleed the brakes 1/ use a brake bleed syringe (ebay about £5.00) Take top off of master cylinder crack open bleed nipple push syringe on to bleed nipple and draw out all the fluid . then fill syringe with fluid and gently squeeze in fluid keeping eye on master cylinder level 2/ remove calliper hold it above resevoire and put something between the pads (thicker than the disc ie tyre lever.Either ways work !!!
Good post Mr wilks " remember to cover tank & plastics, as splash of fluid will mark, even the inside of bubble screen, wash after finished,, as all spills will come to light in weeks to come .. :eusa_doh:
