hi to one an all currently have a 01 fzs 600 fazer its fairly standard scottoiler recently fitted heated grips and fitted hel brake lines today problem is i cant get front brakes primed any suggestions thanks :eusa_shifty: :eusa_shifty:
cheers will give it a go tomorrow moderater thanks btw great site
keep an eye on the level in the reservoir though...dont let the level get too high in there or get it on your paitwork ;)
youll need some small tube wired on to the nipple and syringe, if it leaks from the nipple thread you may have to seal it with ptfe tape. Take care you dont blow the syringe or tube off its fixing and thereby spill fluid on your disk or pads...for that matter take precautions and mask them off first
