February 24, 200520 yr hi i own i 98 t.cat and it currently has a bridgestone battlax bt57r 170/60/zr17. now i want to replace this tyre as its quite worn but acording to info i have the size is wrong can anyone conferm what size i should replace it with and also as its an older type now being replaced by 010 and 020 its a good price at a dearler and they have it in stock as other places say its on back order, is the 170 a better bet than say a 160??????? ta chip
February 24, 200520 yr Moderator If the price & availability of a 160 is good......I'd go with it. Still plenty of rubber for the back end of your Cat.
February 24, 200520 yr Putting a 170 on a cat disturbs the handling, it's just a bit too wide for the width of the rim. Go back to the 160/60 's it should make the handling more confident when leaning over. When I had my cat I put 020 on the back on 010 on the front, worked well enough to get my knee down.
February 24, 200520 yr Author so is it a no no for the 170 or could it be down to own personal taste? 170/60 price is good thats why i was going to get it as my cat already has it on the back so it would be just a replacment. does anyone else have a 170 on the back?
February 25, 200520 yr Moderator You shouldnt use oversize tyres on a bike, as the tyre has to squash up to fit the rim, which increases the height and decreases the radius. And the tyre doesnt perform as it should and the bike wont roll on the tyre as it should so definatly stick to the standard size.
February 25, 200520 yr Never fitted a 170 but all the reports I've read say a big NO NO. In the end you know what yours rides like at the moment with a 170 so it's your choice. Remember different manufacturers tyre shape makes bike handle differently even though they may be identicle size.
February 26, 200520 yr Author thanks everyone...... i decided to call the garage who is fitting my tyre on wednesday and told him i wanted to change the size he also agreed with what you all said.. so thanks to you all from me.. ta
