December 25, 201114 yr hi my bike starts fine i let it warm up a few minutes and get it up to temp and then i set off i can go for about a mile before the engine completely cut out i kick start the bike again and it always starts so i dont think its a fuel problem then when i get another 100 yards it does it again then it just keeps doing it every hundred yards it just completely cuts out, it does idle fine though anyone have any ideas what this could be?
December 25, 201114 yr GREMLINS or GNOMES buggers get everywhere, otherwise check for a fuel blockage or broken ignition wire/earth. Seasons greetings.
December 25, 201114 yr Moderator check fuel tank venting and remove the petrol feed from the carb and see if there is a good flow of fuel
December 25, 201114 yr Author thank you both for your help and hope you both had a good christmas i will check em both tommorow and leave some feedback to how it goes.
