Posted December 19, 201113 yr hi i been having problems starting my aerox i did get it going after a engine rebuild new crank seals bearings piston gaskets and head its also had a new coil on it and petrol tap i replayed my petrol and oil with fresh and a new spark plug i cleaned the carb and i also put on a inline petrol filter i cant get it going there is a bright blue spark lots of compression please can someone help me try to resolve what's the matter with my bike thanks kind regauds daniel
December 19, 201113 yr Moderator if you have a good spark and compression? then it must be fuel supply...so...is the plug getting wet or not? if not why not?
December 21, 201113 yr maybe your inline filter is blocking the fuel, try it without this and see how it goes? you are saying you're getting a spark and there is plenty of compression so it must be fue related, check the pipes are not blocked ect?
December 27, 201113 yr i have a big problem with my aerox 100: 1. when i turn my ignition on nothing comes up and nothing works so its like it turned off. 2. on the starter relay there are two wires when i spark them together it tries to start but just cranks over and does not fire up. i have loads of compression can someone help me asap if you know the problem and i dont reply on here just PM me thanks rhys Edited December 27, 201113 yr by oldgitonabike edited phone number out ...OG
December 27, 201113 yr Moderator On 27/12/2011 at 01:00, p.dott69 said: i have a big problem with my aerox 100: 1. when i turn my ignition on nothing comes up and nothing works so its like it turned off. 2. on the starter relay there are two wires when i spark them together it tries to start but just cranks over and does not fire up. i have loads of compression can someone help me asap if you know the problem and i dont reply on here just text or ring me 07907905257 thanks rhys Great, I have a problem too, some noob hijacking someone elses thread and inviting the world to phone him. Good luck in leaving your number on for the peodo's/spammers/psyco's to find.
December 27, 201113 yr Moderator dont know aerox's but...kill switch off? battery good (horn working) ?
