Adjusting Tappets - xv125
Hi guys,
I should adjust tappet screws on front of front cylinder and rear of rear cylinder as there is an oil leak at both ends. Could be an issue with O-rings there. I think the fitting socket for bolts would be 22mm? I feel like the frame is blocking the adjustment as they seem to be hard for a tool to reach?
Can someone tell me the O-ring sizes I should buy and the precautions I should take?
Thank you! :eusa_think:
there going to be stiff. your best bet would be to see if you can undo them 1st. i tried taking mine off a while ago.......ended up braking 3 spanners then rounded it off.
OMG! So you rounded them up, how the hell would you ever adjust them when things go wrong? Will see if its possible..
