I would like to swap my clocks over to MPH fro KMH
Is it a straight swap when i can lay my hands on some, or is it a change of speedo drive too?
Can i dismantle the clock assembly and just swap the speedo mechanism. This is preferred so that i can keep the clock that is in the XJ900 console but not in the 600 console.
you should be able to buy new clock faces, which really need a pro fitment as those speedos are fiddly buggers to service!
Thanks Drewpy.
Thats sound advice which i think i will follow
You can buy cheap stickers that go over the glass and indicate MPH.
You can swap out the clock for a MPH one.
You can buy adapters like the one above (many bike parts shops do 'em) that make the dial read in MPH.
All are good.
