Cam Chain adjusment
Sammyt80
This post is 4613 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Seemed to remember there is a domed nut on the LH side of the cylinder head you undo and take off with a locknut underneath which you just loosen then loosen the cross head screw then retighten screw and locknut. Can,t remember if this is done with engine running or with the engine at TDC on the compression stroke. Does the Haynes mention this ?
Tony
Link to comment
Share on other sites
