E-Bay Link
Is this for real? 170BHP from this engine?
If so, what kind of maintenance would be involved? Rebuild every 3000?!!?
LOL, what about mpg?
Here's an update, of sorts, for 31.3. 2013
I was chatting with a friend last night about our all time favourite bikes, and mine is my '93 YZF750. It threw a con-rod chasing a BMW M5 one day and that was that. We were looking at pictures of my old bike on BikePicks.com and also found this thread from 2005. The eBay link obviously doesn't work anymore, but I saved the listing details at the time, including pictures. So for the sake of anyone who might come across this thread, or for some of the people who originally posted, and would like a trip down memory lane, here are the details (with mobile numbers removed):
YZF 750 BIG BORE 843CC RACE KIT MOTOR + FLATSLIDES + TITANUIM PIPES + FZR400 3tj FRAME
Hi everybody i have for sale my project which is now impossible for me to build so it has to go!!
1st piece is -
A race spec yzf750 engine but has had a big bore kit fitted!!! to 843 cc!!! This gives it 25% more power than the standard unit. ( this engine gives just under 170 bhp at the rear wheel )
This engine was built from a brand new yzf750 engine and then did 500 miles to run it in on the road.
It has in it
Yamaha Factory Kit race cams
New valves and springs
Gas flowed head done by cosworth (SEE PIC)
Surface discharge plugs
Forged J.E. race pistons
New custom bore liners (+5mm)
New yamaha kit race titanium rods with titanium big end bolts (the bushes have been replaced with solid bushes)
Crank lightened and balanced
All internal engine cases polished/flowed to allow easier oil movement.
The sump of the bike is the race one which basically is 4.5 litre instead of the standard 3 litre
It also has a yamaha kit close ratio gear box in it too.
Being built as a race spec engine they took off the starter and alternator as these add drag and weight to the engine but these arn't hard to get hold of.
2nd bit is
Factory yamaha kit Full titanium exhaust
This system was built by termigoni for yamaha racing team issue.
This is specially made so it comes higher up and closer to the bike for ground clearance but comes round the side of the large sump on the motor!! it comes with an end can.
This has had a slight scrape but has been repaired, it has a small plate welded over the area that was scraped ( the system that is ). The end can looks very dated though so i was going to use the titanium bits and get a new cabon tube and packing and stick a new termigoni sticker on it !! failing this it would take another can anyways. It has had a slight scrape on the joining end of it but could be took off and turned round.
Its the main system that is the thing though specially shaped exhaust ports and stuff and it weighs just 1000g!!! to hold is when you realise
3rd bit is
A set of 41mm flatslide carbs these come with cables.
They need the bell mouths for them but they are nowt. Now people say these arn't for the road as they are too sensitive but these have been altered by some well known race tuner(can't remeber the name now) so that they don't come in with so much of a punch cos unless you were on race rubber it would have spun the back wheel up. ( your going to be doing enough of this anyway with this package as it’s a proper beast!! )
The engine cost about £8000 to build (not including the cost of the new engine) the exhaust doesn't really have a cost cos its from factory yamaha (prob something stupid like £3000 i dread to think!!) and the cabs are a £800 new or something
Also going to throw in a
FZR400 3tj frame swing arm with standard shock, swing arm, brand new gold chain, rear wheel, standard rear brake setup, petrol tank,
Frame comes with log book on a g plate. has been altered to take the yzf engine already and powdercoated black with swingarm. I would value this little lot at about £400 at the cheapest you could find them all.
There is a small dent on the left hand side of the frame but its been checked for straightness and would be fine with a blob of weld in it and a sand up as aluminium is easy to manipulate. (I have done this myself before!!)
You can make your own minds up about the prices but i'm sure you'll realise that its a bargain. I won't negotiate on the price! I won't split it. It may sound like an unrealistic package but i just need the cash i'm afraid!!
This would make your yzf750 a bit of a beast or finish the project off,
if your interested drop me an email or give me a ring my names Fenton my mobile is [removed]. or send me an email and I’ll talk to you about whatever you want know about this. It is available to view at any time you wish just give me a bit of notice on that!!
As regarding postage on this I will think that it would be a fortune so I recon that I can delivery if close enough if you pay my diesel cos but would maybe struggle to get it all in (I do have an estate but its not the tardis!! Ha ha We can meet half way if you’re a good distance away.
For international postage I would have to tot up the weights and give you a price on your individual locations.
Any questions send me an e-mail but I’ll prob not answer till after 6pm mon to fri as I’ll be working. If you require any extra pictures or anything please don’t hesitate to contact.
I have plenty of pictures so please ask and i will take more if you arn't satisfied with what you can see.
Contact to be made within 3 days of auction end and payment within 7 please. Cheque or postal order (if paying by cheque please allow time for cheques to clear)
Paypal - now i will take paypal if its absolutly neccassary for you to pay me but the fees on this ammount will be collosal for me prob cost me £80 so i would much prefer a cheque please people or cash on delivery if i'm to deliver it!!
Many thanks for looking and Happy bidding
PLEASE SEE MY OTHER ITEMS
Check out my other items!
IF YOU JUST WANT TO PLONK THIS INTO A FRAME AND GET GOING I HAVE A FULLY RUNNING ROAD WORTHY AND MOT'D FZR 400 3TJ / 750 WITH DYMAG WHEELS AND AN OHLINS REAR SHOCK OHLINS STEERING DAMPER GSXR 1000 K2 UPSIDE DOWN FORKS AND CAST IRON RACE DISCS ETC ETC. THAT HAS ALREADY GOT A YZF 750 ENGINE IN IT!!! AND ITS GOT STANDARD 400 BODYWORK ON TOO AND ITS ABSOLUTELY MINT WITH EVERY LAST BOLT RENEWED AND METICLASLY BUILT BY SOMEONE VERY PROFFESSIONAL IN THE INDUSTRY!!! WE CAN NEGOTIATE A PRICE FOR THE LOT IF YOU WANT TO LOOK BE MY GUEST!!!!!
bidders with feedback less than 10 please e-mail me first!! thanks guys and gals.
Gallery on BikePic.com: http://www.bikepics.com/members/johnalpi/05yzf750/
2013%5C03%5C31%5Cbikepics-2536191-full.j
2013%5C03%5C31%5Cbikepics-2536192-full.j2013%5C03%5C31%5Cbikepics-2536193-full.j
2013%5C03%5C31%5Cbikepics-2536194-full.j2013%5C03%5C31%5Cbikepics-2536196-full.j
2013%5C03%5C31%5Cbikepics-2536197-full.j
2013%5C03%5C31%5Cbikepics-2536198-full.j2013%5C03%5C31%5Cbikepics-2536199-full.j2013%5C03%5C31%5Cbikepics-2536200-full.j2013%5C03%5C31%5Cbikepics-2536201-full.j2013%5C03%5C31%5Cbikepics-2536202-full.j
That kind of HP is believable from the mods that are described, but like every good Hot-Rod- mpg isn't really figured into the equation. ;)
I bet that Beast sounds Sweet when it's on the pipe with those crank & con-rod mods. B)
I asked the guy, just for fun, what kind of mpg he got, but hes never run it.
If i get £2500 in the next few days, its mine!
Oh i would love that engine in my bike, then again to be honest i cant mak the most of my bike and its only a stage 2. I would shit my self with that in it! :lol:
now that´s an proper race engine.... and as it is, its going to create a major leak in your wallet.
i cant see that engine lasting for 3000 miles without rebuild. its an singlemindedly built race engine and a buyer of such should either deal with the huge cost´s of running it or install it to an yzf750sp frame (mint condition) and only take it out for show purposes.
personally im quite happy with the fzr1000 lump that can be brought to 150 rearwheel hp without seriously messing the reliability.
