Drain Plug???
Ok...I am quite flustered here...I have a manual...but I dont know for sure where to find the oil drain plug on this 88 FZ600...
I have found a plug on either side of the engine...it takes an allen-type wrench....some oil came out....but....maybe just a cup....there must be more in there....I can see some of it grinning at me thru that window....I am also worried that the crazy canuck who owned it before may have run it with low oil.....
any help...pics...descriptions would be great
thanks fellows
Ciao
The drain plug should be under the center of the motor directly behind the oil filter housing in the lower front of the crankcase......if memory serves me correctly, it should be a 19mm Hex-head bolt.
HTH ;)
As you sit on the bike it is underneath the left hand side of the engine ,I dont know if mines been tinkered with but its a normal bolt stylie with a crosshead screw through it .Its here so that you can drop the oil whilst on the stand and the drain plug is at the lowest point(just a note mine sthe 87 model should be the same but !!!!)
Hope it helps
God bless you all!!....there it was....hiding under grease and dirt....and there was oil in the crankcase....which is a relief
You fellows sure are a great help...thanks again
cheers
  • 1 year later...
thanks fellows
Ciao
thge first one you took out on the right hand side is where you would put an oil pressure tester because its in the tunnel of the oil pressure releif valve :D
