XS400 & battery eliminator
I'm guessing you can't run a battery eliminator (capacitor in place of a battery) on the XS400 as it has a field controlled generator?
Maybe if the generator core holds enough magnetism to let it self generate like a dynamo, IE not need a battery to get the generator fired up? I remember mine not running with a knackered battery tho.
If anyone has experience of this I'd be interested to know if the 400 will run batteryless.
sorry, can't be run without a battery. It needs something like 1 or 2 amps to power the field coil.
having said that using a banshee stator you can go batterless
http://www.xs400.com/forum/showthread.php?t=4648
Thanks for that I sort of guessed it wasn't going to happen. Interesting the Banshee generator fitts the 400 as well as the 650!
