fitting wide slab forks to xvs
thinking about fitting these forks to my xvs , click pics to enlarge
Uploaded with ImageShack.us
not sure if i should though the forks have twin caliper brakes at the moment my insurance is 3pft but if i upgrade to fully comp will this put the isurance up alot as the bike with have a bigger than standard brake
will the taper bearing be the same size as the standard xvs items
I can't imagine the insurance going up, since this means you stop *better*!
Not sure on the taper thing, though. I'd have to measure it.
personally i dont think i'd even tell the insurance company
  • 1 month later...
the forks are now on
the upper bearing was the same diameter an tapped staight in the lower was slightly bigger there was a slight lip inside the frame that stopped the old cup going in too far this had to be die grinded ( not much maybe 1/4 of millimetre)
i also had to get the thread extended on steerer tube
pics to follow
