February 7, 200520 yr Can anybody help with advice to deristrict a standard 2001 DT 125 ? Thanks you can remove the half moon shaped washer in the exhaust manifold, that should free up some donkeys!!
February 10, 200520 yr you're knackered mate, the last restriction is in the CDI, and you can't remove it, earlier bikes you just had to turn the powervalve, but that was the models that came without the servo etc
February 12, 200520 yr Moderator Im pretty sure you can fit an older cdi I know you can take it to bits and do some soldering to it, but wouldnt risk that myself
