help please
hello everyone my bikes a sachs roadster with a yamaha virgo 125 cc twin v. i am haveing a problem with starting the bike things i ave done
check plugs for spark
remove carb and fully cleaned
check all pipes or hole rips
put new plugs in
then i fitted it all back together got the bike to tick over a little bit but no revs then i notice it was only the rear engine working .so i removed front engine spark plug no fuel getting into it so i removed rocker cover to make the valves was working and there loads off compression so i put that back together then try to start again but nowt again can anyone help me .
does any1 no wheres best place to get parts from thanks again andrew
Have you checked all the fuel lines/filters to make sure they're not blocked?
check all pipes all ok but no fuel filter on bike .
aswell do u no where the pipe on the inlet goes to
theres probably a filter inside the fuel tank,on the tap - your a bit vague regarding the pipe,how have you been running it with the pipe off?
